• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    paulo
    Accepted Solution
    Two-way and Three-way switch
    255 Views, 2 Replies
    10-02-2012 06:37 AM
    Hello.
    How can I connect a two-way and three-way switch? I need to connect two-way using the same family of switch to two different circuits. I also need to do the same with three-way.
    Please use plain text.
    *Expert Elite*
    Re: Two-way and Three-way switch
    10-02-2012 07:35 AM in reply to: paulo
    A single Lighting Device (Switch) element can be chosen as the "Switch" for multiple Switch Systems. However, a Switch System cannot be connected to two separate switches. So currently, three-way switches are not possible in Revit, and are commonly addressed by adding Shared Parameters to them in order to label them correctly. Searching through this forum should net you some more details on this work-around.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Product Support
    Chris.Aquino
    10-09-2012 08:08 AM in reply to: CADastrophe
    If you would like this functionality added to Revit, this link is setup for you to submit feature requests, or feedback, directly to our Development group.
    I encourage you to use the feedback link as our Development group is always interested and would like to hear your feedback directly, since you are better suited to state the business case for a feature request.
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
