• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    norcaljess
    Accepted Solution
    Transferring pipe fittings
    137 Views, 1 Replies
    10-02-2012 10:00 AM
    I have a project that has already been started. I just received a template and another project which contain pipe fittings that I need in this other project. Is there a way to transfer them?
    Jess
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Transferring pipe fittings
    10-02-2012 11:09 AM in reply to: norcaljess
    Transfer project standards - pipe types
    Or
    Save the families out to library and the re-load them into the new project
    Or
    place an instance of each ftting you want, group them, save them out to your PC or server and then load the model group into the new project
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
