• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    carriehall42
    Accepted Solution
    Title Block parameters
    160 Views, 3 Replies
    09-04-2012 07:00 AM
    We are a small company so the Designed By, Drawn By, Checked By parameters for the title block are the same for every sheet. Is there a way to make these type parameters instead of instance parameters?
    Thanks in advance
    Carrie
    Please use plain text.
    *Expert Elite*
    Re: Title Block parameters
    09-04-2012 07:05 AM in reply to: carriehall42
    No, but I would suggest making it Text in lieu of a Label. Then you don't have to worry about the parameters at all.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Mentor
    julianjameson8403
    09-04-2012 08:13 AM in reply to: carriehall42
    Why not just create a schedule for batch alteration of title sheets and do all three parameters on all the sheets in one go?
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    carriehall42
    09-04-2012 08:21 AM in reply to: julianjameson8403
    I have 2 types of title blocks, Electrical and Mechanical. Text seemed easiest, but I ended up figuring out what I wanted in the first place. I just have a generic label that reads the drawn by and checked by type family paramters. After I woke up and realized what I was doing it was pretty simple.
    Thanks for your input
