• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Text formula
    282 Views, 2 Replies
    06-14-2012 01:54 PM
    I have been trying to get this to work:
    if(Offset = "Left", 1'-0", if(Offset = "Right", 3'-0", if(Offset = "Center", 2'-0", 2'-0")))
    Offset is a text parameter, I am apply this formula to a length parameter. Revit tells me "Improper use of boolean expression" I have also tried using commas instead of equals signs and when I do that Revit tells me "Bad IF-statement format. It should be IF(<boolean>, <result-if-true>, <result-if-false>)." Can someone please tell me what I am doing wrong?
    Please use plain text.
    Re: Text formula
    06-14-2012 02:09 PM in reply to: tbrown6608
    You're not doing anything wrong - Revit does not understand or permit a Text parameter to be used in a conditional statement. There is A LOT of improvement needed with the formulas. I would be happy to help you find workarounds if you wish! I've had to do so many times myself...
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Re: Text formula
    06-14-2012 02:14 PM in reply to: CADastrophe
    Thank you. I will be able to figure out a work around for this it will just require a few more parameters to do what I need to do.
