• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Member
    wilsonjustin1300
    Tagging Diversified Receptacles
    227 Views, 4 Replies
    07-20-2011 08:55 AM
    In Revit MEP 2011 I can put multiple connector elements on a receptacle. I can then connect the receptacle to two different branch panels to create a diversified circuit. The receptacle(s) will show up on both panel schedules.
    When I tag the receptacle only the first panel name and circuit number show up in the tag, is there a way to have a tag show both panels and circuit numbers?
    Please use plain text.
    *Expert Elite*
    Re: Tagging Diversified Receptacles
    07-20-2011 09:05 AM in reply to: wilsonjustin1300
    This is an issue that I had also with light fixtures with two ballasts on different circuits. As far as I have been told, researched, and experimented, secondary connectors cannot be tagged. You would have to employ Shared Parameters to accomplish this task, which requires manual inputs.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Member
    wilsonjustin1300
    07-20-2011 11:25 AM in reply to: CADastrophe
    So I did just that. Created a shared parameter and added it to the tag and receptacle. I also created a fixture schedule with the shared parameter included, and unchecked "itemize every instance", that way If I have to enter the info manually I can at least do it once for multiple instances. This is definitely a work-around , and hopefully it won't come around to burn us in the long run, especially when the deliverable is tomorrow and a list of changes just came in. I hope Autodesk can adress it in future versions.
    Member
    wilsonjustin1300
    07-20-2011 01:52 PM in reply to: wilsonjustin1300
    I actually found an alternative solution from a forum that I subscribe to.
    In Response To:  JWilson18
    Actually you can tag multiple connectors in a receptacle with the Panel Name & Circuit Number information.  My 2 Gang Duplex Split-Switched Receptacle has 4 connectors and I was able to tag every connector with the circuiting info needed.  How?  By creating a short wire (three clicks) from each connector and by tagging these wires.  See attached image.  Isn't it wonderful? Wires are the only Revit objects that I know of that can pick up the circuiting information from each connector inside the same family instance.  You have to be careful though when you move this receptacle because you need to select all tags and wires with your receptacle for everything to follow up.
    Hope this helps,
    Aldo.
    Attachments Summary List
    2 Gang Duplex Split-Switched Receptacle.png;
    Click the attachment icon to left to view & download the Attachments. Please note that it is suggested to use Internet Explorer when downloading attachments to ensure proper file type translation
    *Expert Elite*
    07-21-2011 05:45 AM in reply to: wilsonjustin1300
    Another work-around solution to something that should be basic and simple, but it works. Being careful about moving the devices will be a pain, but manageable. Thanks a ton for posting that information.
