Autodesk Revit MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Summing parameters of grouped spaces in a schedule?
- Highlight
- Email to a Friend
- Report Inappropriate Content
Is it possible to sum parameters of grouped spaces in a schedule? For example, I have spaces in a datacenter hall where 4 of them are supplied by a single common airshaft. I've created a shared parameter for the spaces called AllocatedAirshaft. I would like to group the spaces based upon the AllocatedAirshaft value and do a grand total of the Actual Power Load for the spaces that are grouped together. Is that possible or does anybody have a workaround that doesn't require exporting out of Revit? We'd like for the schedule to be updated in realtime.
Re: Summing parameters of grouped spaces in a schedule?
- Highlight
- Email to a Friend
Yes, that is very possible. In order to group items in a Schedule based on a common parameter value, go to your Schedule View's Properties » Sorting/Grouping tab. Here, you can define the sort order which can include up to four parameters. There is also a checkbox at the bottom of this dialog, "Itemize every instance", which controls whether or not elements are grouped together based on common values - you'll want to disable that option.
Next, go to Formatting tab where you'll see the list of Fields included in your Schedule. Select the Field that you would like totaled, and select the 'Calculate totals' option towards the bottom of the dialog. Note that the Parameter must be of a valid type, meaning that you cannot total certain parameters types such as Text.
⁞|⁞ Please use the
