• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    Space Naming Utility Not Renaming All Spaces
    251 Views, 3 Replies
    03-04-2013 08:50 AM
    I ran the Space Naming Utility and discovered that some spaces are not changing, even though there is a room in the same location.  Any suggestions as to possible reasons why this is happening?
    - Tim Smith
    Motz Engineering
    Revit MEP/AutoCAD/Sketchup
    UC Architectural Engineering c/o 2016
    Lowes Home Improvement
    "There is nothing more expensive than hiring cheap engineers." - Bob Sheeran, Xavier University 01/05/2005
    Please use plain text.
    Re: Space Naming Utility Not Renaming All Spaces
    03-06-2013 11:25 AM in reply to: tim102289
    I've not seen this happen while the Space still shows that it's associated with a Room. Is this a Worksharing Project? If so, is it possible that the elements were uneditable?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Product Support
    03-07-2013 02:22 PM in reply to: CADastrophe
    Have you compared the Room properties with the Space properties (Height, Phase, etcetera)? (Especially since this is only occurring with some of the spaces.)
    Lance Coffey
    Support Specialist
    Product Support
    Active Contributor
    03-10-2013 12:13 PM in reply to: Lance.Coffey
    Yeah I believe it was a phase issue.  It's too bad that you can't cross phase lines with the space naming, because some rooms are being done in one phase, some in the next.  But the rooms are only marked in the phase they are made, not in later phases.
    - Tim Smith
    Motz Engineering
