• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    JColombe77
    Shading stuff
    85 Views, 2 Replies
    04-04-2012 06:15 AM
    I would like to shade VAV boxes, air terminals, ducts, etc
    I think I can do ducts with color scheme but how do I shade mech equipment and air terminals
    Please use plain text.
    Re: Shading stuff
    04-04-2012 06:46 AM in reply to: JColombe77
    You should use View Filters to accomplish that. Using these, you can set specific graphical override (visibility, lines, patterns) to all elements that meet the conditions of the defined Filter Rules. Just reply if you need any more information...
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JColombe77
    Re: Shading stuff
    04-04-2012 06:53 AM in reply to: CADastrophe
    Thanks!  Workign on a auto sizing return grille now once done I will test your method and write back either way.
    Cheers,
