• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    sforsberg215
    Setting up correct views for plumbing
    148 Views, 4 Replies
    11-26-2012 06:18 AM
    Hello, Everyone!
    I have a plumbing floor plan set up into 2 views, one for area "A" and one for area "B". Areas "A" and "B" are placed on their own sheet. The Problem: When I shut off revision clouds in area "A", the clouds in area "B" also shut off in spite of revison clouds and tags set to "by sheet".
    I am pretty sure this is caused by using the wrong type of view. So, what kind of view should one use to set up so they act indepently of each other on the sheets?
    There could be other setting problems I haven't thought of either, so I welcome any suggestions.
    Scott F
    Please use plain text.
    *Expert Elite*
    Re: Setting up correct views for plumbing
    11-26-2012 08:42 AM in reply to: sforsberg215
    Are your areas Dependent Views? If this is the case, then changing the V/G Overrides on any of the Views will also change it in all of the other related Views, both master and dependent. You would have to either make the view Independent or hide the Revision Clouds by Element.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Contributor
    sforsberg215
    11-26-2012 09:12 AM in reply to: sforsberg215
    Thanks.
    So, should Revision Clouds and Tags only be placed/ made on the Sheet, not the view?
    *Expert Elite*
    11-26-2012 09:47 AM in reply to: sforsberg215
    I think that the Revision Clouds are best placed on the Sheet View, for reasons such as avoiding having to deal with annotation cropping and a more easily controlled appearance of the Revisions Clouds. This can be a debatable issue, though.
    11-26-2012 10:51 AM in reply to: sforsberg215
    Yes...On the sheet itself...not IN the particular view
    Mike.
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
