• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    lotta.johannesson
    Accepted Solution
    Self Adjusting RME Families?
    300 Views, 2 Replies
    02-24-2011 03:45 AM
    Hello!
    I have a family creation problem that I never seem to understand. In Revit MEP's own library there are some components that adjust itself according to the host - a duct f.ex.
    How can I create theese families on my own? What is it that makes them self adjust?
    Is it the parameter flow configuration? In Revit they are set to global, if I do the same and don't get the same result.
    Should I have a txt-file (the RME families don't have it). I think I have tried everything.
    Do anyone have an answer? I would be so happy!
    Thx, Lotta
    Fell in love with Revit in 2008.
    Don't forget: Kudos and Solutions!
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Self Adjusting RME Families?
    02-24-2011 05:21 AM in reply to: lotta.johannesson
    I think that the main reason is:-
    The size parameters linked to the connectors have their Discipline set to either Piping or HVAC and their type of parameter set to either Pipe Size or Duct Size (respectively).
    Try making a rectangular box (as a pretend Attenuator) with L, W, H parameters and add parameters to the dimensions. However rather than making the W & H parameters normal length types, make them as listed above. Don't forget to make the family category "Duct Accessory" and the Part Type "Breaks Into". That should work fine.
    Another aspect which may influence this is what Part Type is selected in the Family Category.
    The text file used by some RME families is a catalogue and is just another way of containing all the values used by the parameters to determine the sizes in the families and their types. I allows you to only load a selected number of family types rather than loading ecery type contained in a family if the dimensions use look-up tables, etc.
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    lotta.johannesson
    02-25-2011 07:29 AM in reply to: julianjameson8403
    Thank you so much for your quick replay. I'll try this at once...on monday :smileyhappy:
    //Lotta
