• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    magnolouis
    SECTION GEOMETRY NOT WORKING PROPERLY REVIT MEP 2013
    219 Views, 2 Replies
    10-20-2012 10:00 PM
    Revit  MEP 2013 section geometry is not working properly. Some pipe and Duct etc. are popping up outside the cutting frame. Is there a hot fix for this or just need to work it out on the setting? RMEP 2012 was not like this.
    Thank you...
    Magz
    Please use plain text.
    Product Support
    Chris.Aquino
    Re: SECTION GEOMETRY NOT WORKING PROPERLY REVIT MEP 2013
    10-24-2012 08:38 AM in reply to: magnolouis
    We have not yet been able to reproduce this behavior. If you can provide a stripped down file or screenshot, it would give the community a better idea of what you are seeing.
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
    al.armiger
    04-02-2013 10:33 PM in reply to: Chris.Aquino
    Got the same issue,  It is a bug with the software. When a pipe has
    insulation on, it looks at the bounding box of the insulation so if the
    insulation is on an angle that bounding box becomes quite large. The workaround
    is to turn off pipe insulation in sections... Autodesk are aware of the issue,
    as I have logged to them on another occasion.
