• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Room Names And Numbers
    215 Views, 2 Replies
    12-28-2012 02:33 AM
    Why spaces, cannot get Room names and numbers from the Architectural Room Tag.
    Murat AKAY
    Mechanical Draftsman
    Hvac-Fire-Plumbing-Piping
    Please use plain text.
    Re: Room Names And Numbers
    12-28-2012 05:23 AM in reply to: akaymurat
    Are asking why the Spaces are not automatically named based upon the associated Rooms? If so, Autodesk has a Space Naming Utility (for each release of Revit) that can be downloaded. If that's not what you're talking about, could you explain a little bit more?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    12-31-2012 01:27 AM in reply to: CADastrophe
    Yes, Exactly.. thank you very much your interest.. i'll try download it
    Best Regards
    Murat AKAY
