Autodesk Revit MEP
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Revit to use modified families automatica lly
Options
- Highlight
- Email to a Friend
146 Views, 1 Replies
11-27-2012 02:01 AM
Hi
I have modified the OOTB square to round fitting by simply deleting the flange from the round end, as it is not required. Question is, how do I get Revit to automatically use this modified fitting instead of the original one, so that I don't have to manually exchange fittings after they have been automatically drawn.
Re: Revit to use modified families automatica lly
Options
- Highlight
- Email to a Friend
11-27-2012 05:47 AM in reply to:
lsop1409
The default fittings to be used are defined under Type Properties for each Duct Type. This applies to Pipe, Conduit, and Cable Tray as well.
Corey D.
⁞|⁞ Please use the
.Accept as Solution and
Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
⁞|⁞ Please use the
