• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Westechit
    Revit mep 2012 default template error
    1123 Views, 2 Replies
    02-05-2012 12:03 PM
    This is the error I am getting is
    c:smileytongue:rogramData\Autodesk\RME 2012 Templates\US Imperial\Mechanical-Default.rte
    I have already tryed to do this, add content us imperial content to my revit 2012 mep software 2 times from this option below. Uninstall or change a program, select the Revit application, and click Uninstall/Change.
    http://wikihelp.autodesk.com/Revit/enu/2012/Help/0000-Revit_In0/0001-Revit_In1/0017-Revit_In17/0019-...
    I have also updated revit 2012 mep with the newest service pack 2 from here
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16841348
    We are using windows 7 64 bit operating system
    Please use plain text.
    *Expert Elite*
    Re: Revit mep 2012 default template error
    02-06-2012 01:31 PM in reply to: Westechit
    Post this issue in the Installation & Licensing forum. It's more likely that you'll get a response there.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Product Support
    02-09-2012 04:44 PM in reply to: CADastrophe
    The first thing to do would be to verify if the Mechanical-Default.rte file is located in the folder specified (C:\ProgramData\Autodesk\RME 2012 Templates\US Imperial). If the file exists in the folder, verify if you can open it directly.
    If the file is missing from that location, you could also try doing a Repair on the installation (through the Control Panel).
    Lance Coffey
    Support Specialist
    Product Support
    Autodesk, Inc.
