• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Revit Material Definitions
    372 Views, 5 Replies
    08-08-2011 11:17 AM
    We use .rvt files converted to .dwg files for our detailing work.  There are 10's of thousands of RevitMaterialDefinitions in these files that have to be continually purged otherwise the mouse response slows wwaayy ddoowwnn.  Is there a way to handle these .rvt files so that these RevitMaterialDefinitions aren't so bothersome?
    Please use plain text.
    Product Support
    Chris.Aquino
    Re: Revit Material Definitions
    08-09-2011 03:29 PM in reply to: bobqualls84
    It's not clear what you are doing. Are you working with the .dwg files in Revit, like in a drafting view? Or do you mean and exported .dwg being worked on in ACAD?
    Please give step-by-step instructions to better explain what you are doing.
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
    08-10-2011 03:28 PM in reply to: Chris.Aquino
    Some of the support drawings that we use from others come in .rvt form.  We have to break these down and convert/export? them for use in AutoCAD. (I'm not part of this process so I'm not sure how these drawings are made useful for us in AutoCAD).  Whenever we bring these files in as xrefs there are many RevitMaterialDefinitions that have to be purged otherwise the response time of the AutCAD application slows way down.  Our tech support has tried to clean out these definitions before anyone else uses these files but they have never been successful in removing them just once.  Eventually we all have to purge so that we can do our work in AutoCAD.
    08-11-2011 06:40 AM in reply to: Chris.Aquino
    We get .rvt files, architecturals and structurals, in .dwg format from the general contractor.  The embedded revitmaterialdefinitions can be purged.  What I'm hoping for here is a way to exterminate them.  Here is an excerpt from this morning's log file.  At the beginning of the week these files were in fairly good shape, very low garbage content. It seems like just the process of reloading these drawings from day to day propagates more and more garbage.  These particular architectural and structural files rarely get updated so I wonder why we have to clean our working drawing multiple times daily.  As we reload updated xrefs from the other trades we coordinate with, the volume of revitmaterialdefinitions grows.  Generally we only load the architecturals and structurals once a day.
    Deleting material "RevitMaterialDefinition9988408_18435".
    Deleting material "RevitMaterialDefinition9988408_4465245".
    Deleting material "RevitMaterialDefinition9988408_7322944".
    Deleting material "RevitMaterialDefinition9996404_35341".
    34006 materials deleted."
    Active Contributor
    09-07-2012 04:16 PM in reply to: bobqualls84
    Anyone have any new ideas how to keep these removed from the DWG files?  I purge then save then reopen and the the RevitMaterialDefinitions**** return right away.  It slow AutoCAD WAY down when panning and zooming.
    New Member
    09-19-2012 02:24 PM in reply to: bobqualls84
    Same problem here, the RevitMaterialDefinition s are slowing the drawings very much. They can be purged, but once closed the file and re-open, right away, they seem to be back. If anyone finds out how to remove them permanently, Please share with us!
