• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Revit MEP - Reducing Tee Generic
    348 Views, 1 Replies
    08-20-2012 02:28 PM
    I realize that there have been many posts about the lack of a generic reducing tee for copper pipe. I have made many piping models and as all of you well know, tees are created as standard tees then with reducers to change pipe sizes. After doing some research on other fittings, it appears that I must create my own parameters and look-up tables to create a simple reducing tee. Is this accurate or did I miss something? Any suggestion, solutions of content would be greatly appreciated.
    Phil G
    Please use plain text.
    Product Support
    alan.quinn
    Re: Revit MEP - Reducing Tee Generic
    08-22-2012 10:59 AM in reply to: pgauntt
    Here's a link that will help you. Look at the last response in the thread http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Can-anyone-help-creating-a-reducing-tee-pipe-fittin...
    I also suggest that you post leaving feedback at the below link. Information gathered is used to improve the application.
    Product Contact Link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    Thanks for posting.
    Alan Quinn
    Support Specialist
    Product Support
