Autodesk Revit MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Revit MEP Pipe Sizes - How to change to less than 1"D sizes?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I need to change pipe sizes to 1/2", 5/8", 3/4" or 7/8" diameter, but the program is not allowing it. 1" diameter is the smallest pipe you can change to in Properties. Does anyone know a way to do this?
Re: Revit MEP Pipe Sizes - How to change to less than 1"D sizes?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1/2" and 3/4" sizes should be included by default, at least with RMEP 2012. Verify under Manage Tab » Mechanical Settings » Pipe Settings » Sizes. Ensure that the "Used in Size Lists" box is checked.
⁞|⁞ Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the Reply. I did what you suggested but the problem persists. When I draw my Copper Pipes the results are the same. The pipes sizes start at 1" and will not allow me to select or enter a size lower than that. It also will not allow me to enter a fraction even when accompanied by a whole number. Is there another setting that I am missing?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check "project units" Manage>Project Units.Common>Length>Rounding>Pick a Nearest fraction of your choice. OK out of that and check if you have fraction pipe sizes.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
CADastrophe wrote:1/2" and 3/4" sizes should be included by default, at least with RMEP 2012. Verify under Manage Tab » Mechanical Settings » Pipe Settings » Sizes. Ensure that the "Used in Size Lists" box is checked.
In addition to this, there are a few other things to remember.
You notice the pipe has some parameters under Mechanical called Material, connection type and class.
MAKE SURE the new size you are adding to copper matches the same connection type and class.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
THANKS!!! That solved the problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks! For your imput. The information you provided will help in my setup & template.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your input.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your welcome
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your reply.
How do I check that "the new size you are adding to copper matches the same connection type and class."
Thanks in advance.
