• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Revit MEP Pipe Materials
    2530 Views, 5 Replies
    05-12-2010 08:26 AM
    Here's a rookie question...
    I'm working with hvac equipment and must connect copper pipe for chilled and hot water, and pvc pipe for sanitary drain.
    The Object Styles dialog (MEP2010) only has one setting for "Pipes" which can be set to use copper for material. When I do this, all pipes viewed in 3D are copper, including the sanitary pipes.
    Is there any way to create separate style category entries that allow each piping system to use its own material for rendering?
    What am I missing? Any help is greatly appreciated.
    Please use plain text.
    Distinguished Mentor
    Re: Revit MEP Pipe Materials
    05-12-2010 02:50 PM in reply to: rporter8555
    For rendering purposes
    The different materials that you can assign to the types do not render or show that way.
    You cannot apply a subcatagory to a pipe system.
    You cannot add a material parameter and assign that to a pipe system.
    Your only option is to paint the pipe.
    Each run of pipe has 4 quadrants and can be tedious.
    There is a workaround (as usual) if you have the time.
    If you do not want to render, but just use colors
    You can create filters to acheive this.
    “Anything worth doing is worth doing poorly, until you can learn to do it well.”
    New Member
    05-13-2010 06:42 AM in reply to: rporter8555
    Thanks for the reply. That's pretty much what I thought.
    I created the attached rendering by creating separate "copper" and "pvc" pipe types. I also made copies of the generic pipe fittings for copper and assigned material at the family level. However, I could not find a way to do that for the pipe. I had hoped there was a way to create different pipe systems with different material assignments. You are correct, I could paint the pipe for the sanitary before rendering...
    Maybe this is one for the "wish list".
    Ron
    New Member
    Mattmoot
    01-19-2012 04:07 PM in reply to: rporter8555
    I realise this is a little late to reply, but another work around is to apply a thin insulation thickness to the pipe. Insulation under the object styles can be assigned a different material.
    01-20-2012 10:17 AM in reply to: Mattmoot
    Never too late to reply. Always add information to a post.
    Now that we have 2012 we can add seperate materials to to pipe systems. So problem solved.
    New Member
    03-19-2012 02:01 PM in reply to: rporter8555
    I' m using REvit 2011 in my Office, and I found out that using Phases is a good way to apply materials to pipes or ducts, in addition to  Object Styles and Insulation Material. Of course this method is very limited, but we do what we can with revit 2011.
    I did this render from left to right: EXISTING Phase, DEMOLISHED Phase, TEMPORARY Phase, Object Style for Pipe, and Object Style for Insulation.
    Hope this helps someone.
    Captura
