• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Member
    Revit MEP 2013 - Line Styles Weights
    737 Views, 5 Replies
    09-05-2012 04:33 PM
    I'm not having a problem with my Revit program but i do have a concern on how my piping is shown when i go to vew mode "fine", now that it is 3D the piping is showing up to BOLD, which i really dont like how that looks, so i need direction in how to change the BOLDNESS to a thinner line. I was told it has to do with Line styles but I dont know where i can do this adjustment. Please Help.
    Please use plain text.
    Active Contributor
    tjbeecher
    Re: Revit MEP 2013 - Line Styles Weights
    09-06-2012 07:03 AM in reply to: RodriguezMEP
    Under manage additional setting line weights in there you can see the line weight for each setting.  you can then go to the object styles and play with the projection number to make it thinner.
    Member
    09-06-2012 10:12 AM in reply to: tjbeecher
    how do i get to the additional setting window?
    09-06-2012 10:26 AM in reply to: RodriguezMEP
    Of if you're just using the 3d view for modeling, just use the Thin Lines command (TL keystroke) on the quick access toolbar at the top.
    Active Contributor
    tjbeecher
    09-06-2012 10:32 AM in reply to: RodriguezMEP
    Key stroke should be OS for object styles or under manage/settings/object styles
    Member
    09-06-2012 11:06 AM in reply to: tjbeecher
    This worked.. Perfect.
    Thanks. :smileywink:
