Autodesk Revit MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Revit Circuiting (wiring)
- Highlight
- Email to a Friend
New to Revit MEP still trying to mirgate from AutoCAD.
Is there a way to change the wire properties in Revit to only be drawn at 90degree angles or force the wires to come into the base of the outlet where the connector is located or the top?
This wiring obviously works in America as there symbols are 2 lines and a circle and when the wires find the nearest point to attach it looks correct – with Australian gpo symbols when this happens it turns out quite messy and unable to be read as a A3 print. Even if you go about drawing your own wire chamfer style it still won’t draw exactly straight lines.
Obivously Revit isn't the same as AutoCAD but i would like to clean up circuiting drawings from what is shown in tutorials which looks rather messy.
Re: Revit Circuiting (wiring)
- Highlight
- Email to a Friend
As of now, I think you are of out luck - there is very little that can be done about how Revit draws it's wiring. I dug into something like this a while ago, but I don't think anything has changes since. There can be lots of manual work involved to achieve the desired appearance. Or even hiding the Wiring and drawing simple Lines to represent it instead.
⁞|⁞ Please use the
- Highlight
- Email to a Friend
I feel your pain. Some things I have done to use the wire function is to turn off the homerun arrow in the visbiltiy graphics for the view. Then I don't need to have the wire attached to the device and can end it where I want. If I use the chamfer and have one end short, I can have it make a 90° without chamfering. I have a symbol I use to add the homerun arrow where needed, this has to be to the correct scale of the view I am working in. Not perfect, but it seems to get the desired effect. Good luck.
