• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Revit 2013 How to add a 2" insulation to the duct?
    345 Views, 1 Replies
    10-03-2012 06:49 AM
    Please advise on how to cover the duct with 2" insulation.
    Thank you.
    Please use plain text.
    Re: Revit 2013 How to add a 2" insulation to the duct?
    10-04-2012 07:17 AM in reply to: omileyko
    It should be as simple as selecting the Duct or Duct Run (highlight a section of Duct and press 'Tab') and clicking the 'Add Insulation' tool located on the 'Modify" contextual tab. The following dialog box will prompt for thickness. See image below.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
