• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Revisions 2010
    145 Views, 1 Replies
    04-01-2010 01:32 PM
    Is it possible to use a user wanted revision number for clouding ?? When I try to make a revision cloud it defaults to Revision: Seq. 1 - Revision 1...the job I'm trying to issue a revision for is not using numbers but letters..the actual revision that I need it to be is Revision B...is this possible to do ??
    Please use plain text.
    Valued Contributor
    Re: Revisions 2010
    04-01-2010 01:43 PM in reply to: BrianAd
    Under sheet composition, there's the flyout arrow, click that and change the numbering to alphabetic, and change the discription from revision 1 to Revision A (or B in this case)
