Autodesk Revit MEP
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
RMEP 2011 - no 'Pipe Sizing' tool when a sanitary pipe is selected
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
142 Views, 1 Replies
09-26-2012 08:37 AM
I'm using RMEP 2011. When I select a sanitary pipe (or highlight an entire sanitary run), there is no 'Pipe Sizing Tool' in the Ribbon like there is when I select CW or other supply pipe. Is Sanitary pipe sizing support in RMEP 2011? If so, any suggestions as to where should I start looking for the problem?
Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
Re: RMEP 2011 - no 'Pipe Sizing' tool when a sanitary pipe is selected
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-26-2012 10:33 AM in reply to:
dtiemeyer
It is not supported - probably due to using the UPC or IPC for fixture units, etc.. Sanitary systems will however add up the fixture units so a manual sizing can be done.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
Thank you!
