• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    luchamel2047
    REVIT mep 2013 vs 2012
    833 Views, 3 Replies
    04-20-2012 12:33 PM
    Hi everybody,
    How do I retrieve a file created in version 2013 (trial version) in 2012 ? Is it possible, in version 2013, to save a file in an earlier version?
    Thank you very much
    Luc
    Please use plain text.
    Re: REVIT mep 2013 vs 2012
    04-20-2012 12:47 PM in reply to: luchamel2047
    You cannot save any Revit file as an earlier version. Could you expand on your situation a bit, maybe there's another solution. Was this an existing Revit 2012 file that was opened in 2013 or was it created in Revit 2013? If converted, was this a Project file (.rvt) or a Family file (.rfa)?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    luchamel2047
    04-23-2012 05:46 AM in reply to: CADastrophe
    Thank you very much.
    It's a little project (.RVT file) created in MEP 2013. This is a test I'm doing to see if the problems (calculation of pressure) have been corrected in MEP 2013. I would like to open the file in RVT 2012 whether I would have the same results.
    Have a nice day.
    04-23-2012 06:22 AM in reply to: luchamel2047
    Unfortunately, the method I've heard of to be able to open a Revit project in an earlier version (export/import as IFC file) would not retain your calculations. You will have to recreate it in RMEP 2012 as far as I know.
