• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Member
    Rick21462
    REVIT hOST
    208 Views, 4 Replies
    10-16-2012 01:15 PM
    i'M TRYING TO PLACE AN OUTLET AND IT KEEPS TELLING ME
    Couldn't find an appropriate Host.  Try selecting a different Host Face or switch Placement Mode.
    Can someone help out.
    Please use plain text.
    *Expert Elite*
    Re: REVIT hOST
    10-16-2012 01:24 PM in reply to: Rick21462
    We'll need a little more information, first - Is the architecture 'drawn' in your model or is it linked in from a separate model?
    Are you using an "Out Of The Box" Family? If so, did you load in the family from the MEP folder or the Architectural folder?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Member
    Rick21462
    Re: REVIT hOST
    10-16-2012 01:26 PM in reply to: CADastrophe
    Thanks for responding back. It's a separate model I Uploaded the family from the MEP folder email LOGO Rick Passarella 200 South Wacker Dr Suite 3100 Chicago Il 60606
    *Expert Elite*
    Re: REVIT hOST
    10-16-2012 01:41 PM in reply to: Rick21462
    One of the most common problems encountered is that the Family is "Wall-Hosted" which means that it will specifically require a Wall element to host to. The problem with that is, an imported link is NOT treated as a Wall. For this reason, all of the MEP elements are "Face-Based".
    To check to see if this is indeed the cause, located the outlet family in the Project Browser, right-click on it, and select 'Edit Family'. This will open up the family definition, most likely in a 3D View. Select the "wall" that the outlet is hosted to, and at the top of the Properties Palette, does it read "Other (1)" or "Walls (1)" in the Type Selector? (see image) It should say "Other" if it's a face-based family.
    Member
    Rick21462
    Re: REVIT hOST
    10-16-2012 01:46 PM in reply to: CADastrophe
    Thanks I'll try that email LOGO Rick Passarella 200 South Wacker Dr Suite 3100 Chicago Il 60606
