• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    REVIT 2012 - MEPFS CALCULATIONS
    213 Views, 3 Replies
    08-27-2012 11:01 AM
    I am playing around with Revit 2012 and trying to make it faster (and learn). How do you shut off calculations for mechanical, plumbing and fire sprinkler?
    Is it easy to do? Do some trades turn on/off easier than others?
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: REVIT 2012 - MEPFS CALCULATIONS
    08-28-2012 07:10 AM in reply to: CADFLL
    Within the type properties of duct systems and pipe systems, there is a parameter called "Calculations". Here you can turn off Revit's calculation systems. However - not all pipe systems run calculations, such as the fire protection systems.
    For electrical calculations, go to the electrical settings and turn off "Run calculations for loads in spaces" under Load Calculations section.
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    08-28-2012 07:13 AM in reply to: julianjameson8403
    Where is exactly is this? I was told FS calculations can not be shut off.
    Valued Mentor
    julianjameson8403
    08-28-2012 07:28 AM in reply to: CADFLL
    In the project browser under the Families section.
    That is correct on FP calculations.
    As mentioned previously, not all pipe systems perform calculations. These are the Fire Protection types and "Other" pipe types.
    Thank you!
