• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    aniket_aam
    Re: Query for pipe supports or hangers in Revit Mep
    12-20-2011 09:17 PM in reply to: RalphMounzer
    Thank you so much RalphMounzer for providing me that link. I really felt happy when i saw that link but how shall i insert BIM-ME plugins for Revit Mep Duct support in my Revit Mep 2011 version.
    Aniket Manjrekar.
    Please use plain text.
    New Member
    03-05-2012 06:18 PM in reply to: aniket_aam
    Roofstuff Inc is a global supplier of pipe supports and offers all sorts of sustains like pipe hangers, pipe rollers, duct supports, and many other things online. Well, Roofstuff Inc is a group of professionals as they are offering many piping equipments to contractors, architects, consultants, and building owners to propose a full line quality pipe supports to maximize the piping system.
    Pipe Support
    Active Contributor
    12-03-2012 10:04 PM in reply to: aniket_aam
    Another choice is a small addon for automatically layout and update for hangers, check out the detail from: SupportAndHanger
    Revit Applications provider[revitapp.com].
    Member
    problem in linking a cad file
    12-10-2012 11:47 PM in reply to: aniket_aam
    hi gd mr,
    m new to revit mep software,
    kindly guide me,when i m linking my cad file in revit,a dialoge box appear showing that,
    u r dwg extends greater than 1e9 in autocad units.data exceeding that range will be truncated?
    what to do knw,m using 2011 version ,help me out .
    reply me soon
    Active Contributor
    12-11-2012 02:37 PM in reply to: aniket_aam
    Another option is
    http://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com%3asysquesupport...
    I have not been able to get the automation for association to slab to work correctly but have recieved a call from their support and am working through to resolve.  The hanger setout/positioning works well and they have some additional tools they are developing which look good.
    This tool also is supposed to export setout points for trimble which does not appear to be operational in the test version.
    Options for duct and pipe along with custom hanger families.
    Member
    problem in linking a cad file in revit
    12-11-2012 11:20 PM in reply to: revitapp
    still i hav'nt got any solution regarding my yesterdays fwded msg,
    waiting kindly reply me as soon as posible.
    Valued Contributor
    Sandleaz
    12-13-2012 08:54 PM in reply to: aniket_aam
    How to make pipe supports or hangers in Revit Mep?
    There are many (infinite) ways of creating them.  I would start by going to a hanger manufacturer's website, finding your preferred hangers in their catalog, and creating them in REVIT {Big Purple R (top left corner) ---> new --> family}.  I would categorize it as a pipe accessory.  I'd figure out the dimensions I need (make parameters out of them) to create the hanger and for it to be flexible for my liking.  If you're a beginner, I'd sketch it + the dimensions w/formulas on paper.  After I get my important parameters (I'll add more later if I need to), I would throw a whole bunch of reference planes and associate them with the parameters I created.  Then I create all the solid and void forms I need, constraining them as necessary to the parameters, reference planes, etc... After that, I would create multiple types, one for each pipe size (the parameters I created in the beginning I knew that they either had to be an instance or type parameter --- however I start out with one type) and fill out appropriate values for each type.  I then go through all the types and make sure REVIT can create each type.  If I need to bring other families into this hanger family, I would do that as well (I have my generic nuts and bolts as their own families) --- I'd create the controlling parameters within my hanger family that would control the nested parameters of families that are brought in.  I have pictures of a couple examples attached.  Remember that REVIT does not like certain ways of constraining certain things, so if one way isn't working out, try something else --- this applies to more complex geometries more than simple geometries.
    I also need some Pipe and Duct hangers. Where can i get a Unistrut hanger for Revit MEP? It is kinda bogus that this program doesnt have these out of the box since you need them for basically every mechanical job...
    Kevlar016 ... you understand that the good folks at autodesk aren't going to create everything for you, especially something like hangers and supports --- there are too many different kinds.  Besides, I bet you'd make them better anyways.
    Active Contributor
    01-03-2013 05:51 PM in reply to: Sandleaz
    These hangers are fantastic, very impressive.
    YeahSo Hanger
    Valued Contributor
    Sandleaz
    01-04-2013 12:49 PM in reply to: revitapp
    Thanks revitapp.
