• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Projecting Centerlines
    145 Views, 3 Replies
    09-14-2012 12:32 PM
    All elevation views including arch views with MEP linked model are displaying pipe, duct, conduit, etc. Centerlines as if they were projecting to the outside wall. (looks like buckshot crosshairs.
    I am able to turn them off centerlines in VG but that is a big effort over many views.
    Any thoughts on what can be controlling this apparent projection?
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Projecting Centerlines
    09-17-2012 02:53 AM in reply to: jbecker
    How about try using view templates to control the visibility of centrelines for various elements?
    The view's detail level will also affect how these display.
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    New Member
    09-17-2012 04:15 AM in reply to: julianjameson8403
    Yes, we are using view templates to correct the problem. Still a labor effort. Thanks.
    The question is why the centerline "projection" is occurring in the first place. Are there any control options for centerlines which would limit the visibility?
    I do not understand why (single example) a pipe 50 feet inside the building is "projecting" its centerline thru the outside wall. The pipe does even run perpindicular to the wall. It is a open end pipe not yet connected to anything else.
    Any additional thoughts would be appreciated.
    Product Support
    Chris.Aquino
    09-18-2012 07:00 AM in reply to: jbecker
    I would check the depth of the elevation to make sure the pipes that are showing are not in it. I would also check to see if depth clipping is on or off.
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
