• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    CADArmor
    Pipes Risers/Droppers - Ceiling/Floor Plan
    725 Views, 11 Replies
    08-15-2012 08:39 PM
    Problem please HELP - Please see image 01 attached. In our drawings we have always set our drawings up this way, if the pipes run in ceiling cavity we will use Reflected Ceiling Plan because our sprinklers are attached to the ceiling and if the pipes run below ceiling we will use Floor Plan. Recently discovered if looking at the Ceiling Plan our pipes appeared to be rising instead of dropping and if you set up a Floor Plan the pipes appear to drop down which is correct. The View Range is identical for both plans – looking down from above. Can someone please help?
    Please use plain text.
    Re: Pipes Risers/Droppers - Ceiling/Floor Plan
    08-16-2012 05:53 AM in reply to: CADArmor
    In a Plan view the orientation is top looking down. On a Ceiling Plan the orientation is from the floor looking up which is why Up/Down is reversed.
    The way we handle that is to shut off all piping on the ceiling plan and only show hosted elements (sprinklers). On the floor plan we turn on our sprinklers and route all piping from them.
    Then on the sheet we place the Floor Plan view and then the Ceiling plan view on top to represent the ceiling grids and patterns. 2 views placed in the same place on the sheet.
    It won't matter that you are showing sprinklers in both plans since they will line up on the sheet and you won't even notice.
    Valued Contributor
    AnmarieJames8335
    08-16-2012 09:56 PM in reply to: CADArmor
    A reflected ceiling plan, both in drafting theory and in Revit, looks up from below. It's meant to show the ceiling and anything set into it. Anything above the ceiling will show hidden or dashed because it's considered "beyond" the ceiling plane. To get your piping symbols to show above the ceiling the same way they do below, you'll need to create another floor plan view, this one with the View Range set higher to eliminate items below the ceiling. Anmarie
    CADArmor
    08-16-2012 09:56 PM in reply to: dannyv79
    Thank you for your explanation. Much appreciated. Problem solved! -- Message protected by MailGuard: e-mail anti-virus, anti-spam and content filtering. http://www.mailguard.com.au
    Valued Mentor
    julianjameson8403
    08-22-2012 12:59 PM in reply to: CADArmor
    Or alternatively place a new level in your model set to the ceiling height which basically shows the contents of the ceiling void. Easier than taking a floor plan based on the floor level and messing about with heights above the floor to capture the contents of the ceiling void.
    One thing to be aware of though is, differing ceiling heights and the effect this will have on view ranges, etc. You may have to piece together either different floor plans or call out to achieve the required look.
    Don't bother with plan regions - this don't work overly well for MEP stuff.
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    CADArmor
    08-22-2012 10:58 PM in reply to: dannyv79
    Thanks Mate,
    We created two plans, ceiling and floor plan. All our services are drafted in Ceiling (Only for aligning sprinkler with ceiling grids) and Floor Plan.
    This is what we've done:
    (1) We overlaid both plans on a sheet.
    (2) Align them using Grid Lines
    (3) In Floor Plan Go to VG - Revit Links and untick architectural background. (Only showing services)
    (4) In Ceiling Plan Go to VG and turn off all Services in Worksets. (Only showing ceiling plan.)
    This will show floor plan (only showing piping and sprinklers) overlaid on a ceiling plan (only showing a ceiling plan)
    The only problem is time and it’s quite hard to align them perfectly.
    08-23-2012 05:42 AM in reply to: CADArmor
    When placing a view on top of another view in a sheet you should be able to locate the views center point both horizontally and vertically.
    When placing the second view slowly cross over the sheet and you should see a blue dashed line come up, then slowly bring your view up until you see another blue dashed line.
    When you see both lines on the sheet crossing over eachother click to place your plan and they should be lined up.
    CADArmor
    08-27-2012 10:15 PM in reply to: CADArmor
    Heya mate,
    Thank you but I found another way and much easier and faster. Firstly create a ceiling plan only showing the ceiling. Secondly in floor plan underlay with the new ceiling plan you’ve created. (Underlay Orientation). Your plan will show symbols correctly on a ceiling plan but actually it's remains floor plan.
    Valued Mentor
    julianjameson8403
    08-28-2012 02:15 AM in reply to: CADArmor
    Yep - forgot about underlay option. Don't use it that often so not high on my list of methods. However will remember for future - thanks.
    Thank you!
    New Member
    Re: Pipes Risers/Droppers hidden lines
    05-20-2013 07:02 PM in reply to: dannyv79
    can someone please help. i dont know how to show the pipework dropper in hidden lines. is there a quickway to do this? i use revit mep 2012 and i have already set linework hidden in MEp settings. refer to attached snap shot please.
    Thank you
