• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Contributor
    Pipe fittings not scaling to pipe size
    1325 Views, 5 Replies
    08-11-2010 06:10 AM
    I am placing 6" pipe, doesn’t seem to matter what type, and the elbow won’t appear larger than 1". the elbow fitting says it is 6", but only shows and measures as 1". see attached image.....
    Please use plain text.
    Re: Pipe fittings not scaling to pipe size
    08-11-2010 06:47 AM in reply to: munsellh
    i figured it out..... my revit ini had a wrong setting
    my LookupTableLocation was not set properly.
    Active Contributor
    08-25-2010 04:47 AM in reply to: munsellh
    I currently have this same problem.  Can you walk me through this process of how to fix this?  I can't really draw any of my pipe in until i fix this problem.  Thanks.
    Distinguished Mentor
    08-30-2010 12:55 PM in reply to: onuswim
    Go to C:\Program Files\Autodesk\Revit MEP 2011\Program and open your Revit .INI file (notepad).
    You will see the code that begins with
    LookupTableLocation=
    and
    ENULookupTables.cab=
    make sure that the paths are correct.
    “Anything worth doing is worth doing poorly, until you can learn to do it well.”
    New Member
    joedraftsman
    06-28-2011 08:46 AM in reply to: munsellh
    Here was the solution to my problem:
    I found that in my Revit.ini file the LookUp file location line ended in the word PIPE, I just removed the word PIPE and everything works now.
    That line and the ENU file location line do have to match.
    LookupTableLocation=C:\ProgramData\Autodesk\RME 2011\LookupTables\
    ENULookupTables.cab=d:\ProgramData\Autodesk\RME 2011\LookupTables\
    Member
    sllana
    09-03-2012 01:57 PM in reply to: joedraftsman
    Well, I did all of these and nothing happened, pipe fittings still not scaling to pipes.Except my ini file doesnt have the line ENULookup...    (but mine is 2012)
    . . . and I couldnt add it because of administrator restrictions. could it be that? No further ideas?
    p.s. please and thank you all.
