• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Contributor
    Accepted Solution
    Pipe drop/rise annotation size
    1365 Views, 13 Replies
    05-13-2009 11:08 AM
    From reading through the forums, I understand how to change the annotation scale of pipe fittings and single line symbols. But am I correct in saying that this setting does not affect the size of the single line pipe drop/rise symbol?
    Please use plain text.
    Employee
    Re: Pipe drop/rise annotation size
    05-13-2009 03:01 PM in reply to: bsepter
    Correct.
    Rise drop is:
    Manage > MEP Settings > Mechanical Settings > Pipe Settings > Rise / Drop > Pipe Rise / Drop Annotation Size.
    Martin Schmid, P.E.
    Product Manager - Analysis and Countrification
    Architecture, Engineering, and Construction
    Autodesk, Inc.
    Valued Contributor
    05-13-2009 06:38 PM in reply to: bsepter
    Just when I think I've tried everthing and clicked everything, the setting was right under my nose. Thanks Martin.
    Member
    ccossey
    08-09-2011 02:04 PM in reply to: bsepter
    In RevitMEP 2012, the "Pipe Rise / Drop Annotation Size" will not allow you to adjust the size below 1/8".  The rise/drop symbols in the model and on paper are way too big at that size.  Is there another way to adjust the annotation size?
    Product Support
    Chris.Aquino
    08-09-2011 03:11 PM in reply to: ccossey
    In 2012, the Annotation Size is tied to the Pipe Size in Project Units, which is set to round to 1/8" by default.
    Go to Manage > Project Units > Piping > Pipe Size and set rounding to less than 1/8". This should fix the issue.
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
    Member
    ccossey
    08-10-2011 05:24 AM in reply to: Chris.Aquino
    That worked!  Thank you, that was frustrating...
    Member
    BIMQueen62
    10-13-2011 11:47 AM in reply to: Chris.Aquino
    Thanks - we where finding the same problem. In my testing I found that this works also. The problem is not knowing this when you edit Pipe Rise / Drop Annotation Size from the Mechanical Settings - work and save beyond the point of undo - then try to correct through Project Units, it is already broke and does not seem to be fixable. We know have 12" symbols for up/down on a huge VA project.
    1st Question - is there a fix from this point?
    2nd Question - why move a Mechanical Setting to Project Units?
    Member
    ccossey
    10-13-2011 12:53 PM in reply to: bsepter
    Aquino,
    Did you go back and change your mechanical settings after you changed the project units?  Changing the project units just allows you go use a number less than 1/8" (or whatever you set it to) then, you have to go into mechanical settings and change the rise/drop to whatever you want it to be.  I was able to get my rise/drops to change mid-way through a project.
    Hope this helps,
    Cossey
    Member
    BIMQueen62
    10-13-2011 12:58 PM in reply to: bsepter
    Super! Yes that worked!!
    Member
    kvanatta
    10-28-2011 11:54 AM in reply to: BIMQueen62
    Shouldn't this method also work for pipe fittings? I can't get our fittings to look smaller.
