• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Mentor
    dennis
    Pipe System Flow Calc
    399 Views, 5 Replies
    01-03-2012 06:33 AM
    I am getting FLOW for every pipe system, except Sanitary.  Is that something that isn't usually figured, or am I missing something?
    Please use plain text.
    Distinguished Mentor
    asommer
    Re: Pipe System Flow Calc
    01-03-2012 12:55 PM in reply to: dennis
    There is something with that, I think it can size based on the connected loads, but not show flow in the System Browser.  I'm not exactly sure, but I know there is something with the Sanitary that doesn't work, so you are not the only one.  Maybe it is expected that there is NO equipment on the downstream end, although you may have a sewage pump sometimes.
    On the same note, I had tried to "Finish" a Domestic Water System with a "Meter" to get the building Demand as calculated in the System Browser, and I could not get it to work.
    Valued Mentor
    dennis
    01-09-2012 09:06 AM in reply to: asommer
    I too found myself trying to close out a Cold Water System, and what I found was a family in the library: Mechanical Equipment / Pipe Connector - Domestic Cold Water - Plumbbing Equipment.  Load it, edit Family, set the connector to be "Calculated" and "Loss Method" as "Specified".  Hook it into a well connected cold system and it closed up the system giving me the overall flow value.  There is a similar family for the sanitary that i will check next.
    asommer
    01-09-2012 12:49 PM in reply to: dennis
    Does that show up correctly in your "System Browser"?  I want to make a "Water Meter" out of this if it works.
    Valued Mentor
    dennis
    01-10-2012 04:34 AM in reply to: asommer
    I also found some PipeAssessories:Water Meter based on HERSEY METER at Revit City.  I had to tweek the connectors slightly, mainly matched up how the PipeConnector family previously mentioned was setup.  It closes up the Cold Water System to where there are no more 'warning triangles' when I use the "Check Pipe System'.  And yes, the System Browser appears correct to me.
    asommer
    01-10-2012 07:35 AM in reply to: dennis
    Cool.  I will definitely look this up.  Thanks!
