• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Pipe Accessory Family
    252 Views, 1 Replies
    06-22-2006 12:24 PM
    What would one use to create a valve family. I don't see an pipe fitting template like the ones for ducts. Any insight on this would be appreciated. Thank you.
    Please use plain text.
    Employee
    Re: Pipe Accessory Family
    06-23-2006 11:24 AM in reply to: rafterman
    Start with the Generic Model.rft. In the settings menu, click Family Category and Parameters.
    Set the Category to Pipe Accessory, and try the following Parameters:
    Work Plane-Based = unchecked
    Always Vertical = checked
    Behavior Type = Break Into
    Part Type = Valve
    Shared = unchecked
    HTH,
    Martin Schmid
    Autodesk Consulting
    Martin Schmid, P.E.
    Product Manager - Analysis and Countrification
    Architecture, Engineering, and Construction
    Autodesk, Inc.
