Autodesk Revit MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Phasing and Designatin g families to be existing
- Highlight
- Email to a Friend
Is there a setting for designating a component to be in a particular phase?
Does Revit know what to designate the selected component prior to placement?
I am trying to place a sprinkler head in an existing view, using the existing phase in the view but it wont display, so I have to go to the new view select the sprinkler head and change the phase created in from New to Existing.
Any suggestions are appreciated
Re: Phasing and Designatin g families to be existing
- Highlight
- Email to a Friend
Check out >this thread< and if you have any questions or anything, don't hesitate to ask!
⁞|⁞ Please use the
- Highlight
- Email to a Friend
To place existing equipment, set your phase filter to Show All, and your phase to Existing. As you've seen, if your Phase is set to new construction, anything you try and place in an existing view will not be visible.
- Highlight
- Email to a Friend
Thank you that helps a great deal
I should have mentioned we have linked files with phasing to consider also.
Is it typical to link the Architects model and set the phasing to match what they have set?
Also, if you have a core and shell linked into the interior fit out with different phasing which takes precedence?
Is it better practice to link these files separately in order to deal with them separately?
- Highlight
- Email to a Friend
kadmonkee8 wrote:"Is it typical to link the Architects model and set the phasing to match what they have set?"
Yes. Typically, you manually create the Phases in your project to match those Architect's. Then you would check the Phase Mapping to ensure that the projects are in sync. To check Phase Mapping, select the Link in any View and go to Type Properties.
kadmonkee8 wrote:"Also, if you have a core and shell linked into the interior fit out with different phasing which takes precedence?
Is it better practice to link these files separately in order to deal with them separately?"
Does that mean that the Core and Shell exist in separate models? If that's the case, then the phasing would be determined by Phase Mapping, as per my previous response above. I believe that it would be better if the entire architecture was in a single model, barring that this would be necessary to reduce the file size of a monstrous project.
⁞|⁞ Please use the
- Highlight
- Email to a Friend
yes in this particular project the 2 models are separate and then linked independantly to our discipline models
the phase mapping is also different in each linked model (thus all my confusion)
- Highlight
- Email to a Friend
Well, then they'll be linked in separately. Could you list the Phases from each model and their intentions and relationship to each other?
⁞|⁞ Please use the
- Highlight
- Email to a Friend
i have attached a doc with screen shots and phase , phase filter description of the 2 files in question
- Highlight
- Email to a Friend
The Phase Filters appear to be the same for both project, which is good, but can you post an image comparing the info from the Project Phases tab?
⁞|⁞ Please use the
- Highlight
- Email to a Friend
actually the phase filter settings are the same, but the phase filters being used in the views in each model are different.
maybe i am overthinking this.
i am unable to post images of the project due to privacy issues.
