Autodesk Revit MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Panel Schedule Templates - Location Parameter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having problems with the "location parameter" in the panel schedule template. The parameter doesn't reference correctly, and there doesn't seem to be a way to update it if the space name should change. I've attached a screen capture of the panel schedule template.
Any suggestions?
Re: Panel Schedule Templates - Location Parameter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When you are in the panel schedule, I believe there is a button to "Update Names". Either click in the cell that has the location and select "Update Names" or just select "Update Names". I believe that is going to do what you need.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You cannot select the location when in the "edit panel schedule" and update the "location" parameter the same way you can update names in the cells.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Whenever a change is made to a panelboard, the schedule is updated to reflect that change. This includes, of course, modifying any of the parameters, adding a circuit, and so on. However, when the Space Name is changed, Revit does not register any actual change to the panel, even though the location data was indirectly modified. So, in order to "refresh" the schedule, you have to make some sort of change so that Revit sees a reason to regenerate the data.
Some possible methods:
- Plan View: With the Panel Selected, edit the header or footer notes (whichever is blank) and enter a Space.
- Plan View: Move the Panel 1" and then immediate Undo it.
- In Schedule: Change a random parameter such as a Circuit Name and then hit Undo.
- In Schedule: Click "Change Template" and then just click 'OK' to select the same template it already is.
I would definitely call this a bug.
***TESTED IN REVIT MEP 2012***
⁞|⁞ Please use the
