• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    sforsberg215
    Open piping - How do you handle it?
    248 Views, 2 Replies
    10-02-2012 07:48 AM
    Everyone
    Hi. I understand that Revit will not run a fixture unit count if any piece of piping is open, ie not connected to anything. How have people gotten around this problem with vent piping, and piping entering and leaving the building?
    Please use plain text.
    Re: Open piping - How do you handle it?
    10-02-2012 09:36 AM in reply to: sforsberg215
    Adding a cap is the easiest option.
    Distinguished Contributor
    10-11-2012 07:35 AM in reply to: abulla
    Its my experience that if you change the SAN elbow into a tee then contiue drawing with Vent 'system' pipe, the fixture count is lost, even if the vent pipe is capped.
    Has anybody found a solution or workaround to this?
    The outside connection can remain open, as long as the rest of the system has no openings.
    Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
