• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    zingero84
    No auto route solution found for no reason
    931 Views, 2 Replies
    01-20-2012 04:25 AM
    All,
    I am an experienced Revit user.
    In one of my models, I am getting the "no auto route soltuon found error" all of the sudden for no apparent reason.
    I was working in it yesterday with no problems.  When I opened it up today and tried to draw ductwork, I got this error.
    I get this error when I do ANYTHING with ductwork.  If I try and connect to existing, modify existing (just shorten or lengthen), try and draw a new piece off in space, etc...
    My model as of right now is completely useless and I have no idea how to fix this error.
    I tried auditing the model and that didn't fix it.
    In addition, in my other models, I have no problems whatsoever drawing ductwork, connecting, modifying, etc...
    Any ideas?
    Please use plain text.
    Distinguished Mentor
    Re: No auto route solution found for no reason
    01-20-2012 09:58 AM in reply to: zingero84
    That is a head scratcher.
    Usually that error (and I'm sure your aware) is from undefined fittings in the duct type or lack of necessary space to place a fitting.
    You mentioned just drawing a straight segment of duct gives you this error?... Perhaps there is an issue with the Duct Profile CSV file specific to this project.
    The strange thing is any file location settings within revit aren't per project, but rather global, especially if it is working in a new project or another existing.
    Do you have your journal files? <located here-->C:\Users\yourname\AppData\Local\Autodesk\Revit\Autodesk Revit MEP 2012\Journals
    Open a new project and drag and drop a previous journal file to see where it broke. There is a  software called baretail that makes it easier to go through the journal as a step by step macro interface.
    If there is nothing you can do, I would send Adesk the file
    (if your on subscription) and let them figure it out.
    “Anything worth doing is worth doing poorly, until you can learn to do it well.”
    Product Support
    Chris.Aquino
    01-23-2012 03:41 PM in reply to: zingero84
    To get a better idea of what is happening, please upload the journal file from a session where you got the error.
    Chris Aquino
    Revit Support Specialist
    The Revit Clinic
    @Revitclinic
