• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Re: No Hub cast iron fittings
    01-07-2013 11:45 AM in reply to: BRYANBRAUER1832
    BRYANBRAUER1832 wrote:
    Yes.  I used the elbow and lookup table from the link which you attached to your previous post.
    I just re-downloaded the zip folder I posted, put the look-up table in the correct folder and the .rfa folder in my library. I then opened a new project after closing Revit down, re-added the quarter bend to the routing preferences, and it still shows up the same as before with a "broken leg." What gives!? :smileymad:
    Please use plain text.
    Active Contributor
    BRYANBRAUER1832
    01-07-2013 01:01 PM in reply to: MikeSavko6811
    Have you tried printing it?  Sometimes stuff shows up strangly on my display, maybe an issue with my video card, but plots properly.
    01-07-2013 01:05 PM in reply to: BRYANBRAUER1832
    Haha well I'd much prefer having YOUR issue where the fitting shows up properly. Haven't tried printing.
    Distinguished Contributor
    01-08-2013 09:03 AM in reply to: MikeSavko6811
    Have you tried contacting Charlotte??  There might be a bug that they can fix but havent been told there is something wrong.
    http://www.charlottepipe.com/Default.aspx?Page=TechProdSupport
    Try any of them and ask if they could forward to the person responsible for creating their Revit content.
    01-08-2013 09:09 AM in reply to: RKLindner
    This whole thread is a great lesson on why you should be cautious using manufacturer content. :smileywink:
    01-09-2013 06:24 AM in reply to: RKLindner
    Just sent that Brian an email to see what he has to say. Has anyone else tried downloading the link I posted and seeing if their quarter bends draw like mine?
    Active Contributor
    BRYANBRAUER1832
    01-17-2013 03:37 PM in reply to: MikeSavko6811
    Well Mike, I was so encouraged that my Charlotte no hub elbows displaying properly that I decided to take another fling at using no hub fittings.  When I first told ypu that the elbow displayed properly for me, it was when I inserted the elbow in my model and drew pipes from both connections.
    So I configured a no hub pipe type with the no hub fittings in the routing preferences.  Low and behold!  When I constructed a 90 degree bend REVIT inserted a no hub elbow with dicontinuos display of piping at one of the connections, just as you described.
    So now I am back to modeling with PVC DWV and specifying no hub cast iron.  It is indeed an imperfect world, and REVIT is less perfect than we have reason to expect.
    01-18-2013 05:11 AM in reply to: BRYANBRAUER1832
    Ahhhhh...fancy that. Revit is certainly behind when it comes to MEP.
