• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit MEP
    Member
    No Hub Pipe
    337 Views, 3 Replies
    07-25-2007 12:41 PM
    I am generating Cast Iron No Hub fittings using the dimensions from the ASTM standards and have a couple of bends/sweeps completed. I am showing couplings as part of the fittings (half of a coupling on each end of the fittings) and have been successful. The problem i am having is on the pipe connecting fittings - how do i get the "half coupling" generated on the ends of straight pipe?
    Please use plain text.
    Re: No Hub Pipe
    07-27-2007 05:47 AM in reply to: rkootstra
    I have not yet been so ambious as to try to create pipe and fitting content. But, might I suggest you try starting with Charlotte Pipe's 3D ACAD files. They are online or you can request a CD. There is no cost. I have used these files many times in AutoCAD to make sure I had the required space for fitting stacks.
    Start here:
    http://www.charlottepipe.com/Default.aspx?Page=AllDrawings
    If REVIT had partnered with folks like Charlotte I think the content in the program would have been much better, more accurate and complete.
    I would love to see some of the content you have created.
    email @
    sernspiker@luckett-farley.com
    New Member
    Re: No Hub Pipe
    11-01-2012 11:23 PM in reply to: rkootstra
    I don't know if it will work but I would try a "half coupling" as a flange. Let me know if it works.
    I would be interested in checking out your fittings. I downloaded charlotte's no hub fittings and besides not working well... They sizes are not accurate!!!!
    Jasonjmattox@gmail.com
    Re: No Hub Pipe
    12-27-2012 06:49 AM in reply to: rkootstra
    Found this in a Google search. I'm very unsatisfied with the fittings from Charlotte's website. Their quarter bend doesn't fully extend on one leg to the connecting pipe so it doesn't look correct at all. If you are freely sending out the fittings you've created, I'd be interested. msavko@proutboiler.com Thanks!
