Autodesk Revit MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
NEED HELP NOW!!
- Highlight
- Email to a Friend
I'm a student working on m final project. I am having some type of issue with installing certain lights. For some reason recessed can lights and general idustrial type lights will not let me place them in my project. Below is a screen shot. you can see the light, but it won't move and the mouse icon is a cirle with a line across it, saying not allowed. I've tried every view, changed cut plane, turned on all graphics, and nothing. It won't even give me the option to place on face. Does anyone know what i can do?
Thanks.
Re: NEED HELP NOW!!
- Highlight
- Email to a Friend
Where did you get the light fixture family? Seems like it should work, if it came frome the Imperial Lib. If it is custom, you'll have to open the family to troubleshoot. What are you trying to host it from, a level, a ceiling? When this type of thing happens to me, I isolate my intended host in that view, and try again.
Re: NEED HELP NOW!!
- Highlight
- Email to a Friend
I pulled in the Pendant Light - Linear - 2 Lamp fixture into a simple model. I too got the "international no" symbol (circle with a line through it) but only while my cursor was outside my ceiling grid. As soon as I hovered over the ceiling, the fixture appeared and I was able to place it.
So, I'd say this family requires a ceiling to host it. Maybe create a ceiling off to the side (or in a blank model) and try adding the light fixture there. If that works, you know it's not a visibility thing, but something related to your ceiling.
FYI, lights can't host to ceiling grids in a linked model. If that's the case, you'll need to create one in the same file as the light fixture.
Good luck!
AJ
Re: NEED HELP NOW!!
- Highlight
- Email to a Friend
I ran into this before, where Lights and diffusers that normally place on face with no trouble decide not to allow it. I had to create a 3D view with just ceilings, Lights and diffusers turned on, and place families in the 3D view.
Re: NEED HELP NOW!!
- Highlight
- Email to a Friend
It's from the revit seek library. I did'nt change any family constraints or adjust anything.
It won't work even over a ceiling grid.
And I tried to use the 3D view also.
The fixture won't even move with the mouse cursor.
Re: NEED HELP NOW!!
- Highlight
- Email to a Friend
1) If this is a Ceiling hosted fixture, it will not attach to anything in a Linked model because Revit MEP does not recognize Ceilings or Walls, simply Faces.
2) If you are in the original model and this is Face based, make sure that the 'Place on Face' is selected, and not 'Place of Vertical Face'.
Have you opened the Light Fixture family and reviewed it?
