• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Re: Multiple filters and Clearances
    10-31-2012 08:37 AM in reply to: armando
    Hi armondo,
    Welcome to the Autodesk forums!
    The technique you've describe here is a good one, but the View Filter's color overrides WILL still hit the Detail (or Symbolic) Lines within the Family, not just the model elements.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Please use plain text.
    Member
    armando
    10-31-2012 09:37 AM in reply to: CADastrophe
    I do this all the time. Are you sure you used Symbolic/Detail Lines inside of the family to represent the clearance? I attached a pic of one of my vav's colored by filter and still showing my dashed red line to symbolize clearance. Let me know if you are doing the same steps, or upload a simple family that is not working as I have described and I'll take a look at it.
    10-31-2012 10:09 AM in reply to: armando
    Attached is a sample project with a Mechanical Equipment family (including Symbolic Lines), and multiple graphical situations. Revit MEP 2013.
    Member
    armando
    10-31-2012 10:58 AM in reply to: CADastrophe
    I just did it here from your own file. Is this not what the Thread Opener desired? Perhaps I'm confused as to what he wanted to accomplish. Let me know if I shoudl also upload the .rvt.
    10-31-2012 11:06 AM in reply to: armando
    OK, I see. So you set the View Filter to override the Projection/Surface Pattern, right? Based upon the OP's attached image early in this thread, he's aiming to change the Mechanical Equipment's Lines to brown, whist keeping the Lines of the clearance zone red.
    Active Member
    10-31-2012 11:08 AM in reply to: CADastrophe
    Can you put a snapshot of your filters? I have the impression that you don't overide the line type.
    Here's mine.
    Member
    armando
    10-31-2012 11:09 AM in reply to: CADastrophe
    Yes I should have been more clear, the only setting I touched on the view filter is the Projection/Surface Pattern Overrride. And thanks for welcoming me to the forum, been a long-time lurker.
