• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Contributor
    Linked Room Tags
    116 Views, 2 Replies
    10-24-2012 08:38 AM
    I have an architectural model (with rooms placed and tagged) (revit 2012).
    I link this model into my project, but I can not tag the rooms.
    When I turn on room fill nothing shows up.
    Any idea what the issue may be?
    Please use plain text.
    Re: Linked Room Tags
    10-24-2012 08:51 AM in reply to: spm5
    Two possibilities:
    1. The Rooms Category is turned off in V/G Overrides. Also check to make sure the Link's V/G's are not overridden under the Links tab.
    2. The Cut Plane, under View Range, may be set to 0' - 0". If the Cut Plan does not cut through a Room, that Room will not be visible.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    10-24-2012 08:52 AM in reply to: CADastrophe
    It was a stupid mistake. The phases were not mapped properly.
