• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Contributor
    thombrady
    Accepted Solution
    Link in the Way
    157 Views, 3 Replies
    10-17-2012 04:24 AM
    I have taken a Cad file, turned it into a family, loaded it into a project & linked that project into the REAL 4 floor project I am working on. NP, everything looks great, shows up in section & everything. The issue being that it shows up in 2D on every single view & while it is not that big of a deal I am wondering if there is a way without unloading it to shut it off in all views at once instead of seperately?
    Please use plain text.
    Re: Link in the Way
    10-17-2012 04:35 AM in reply to: thombrady
    First, why did you make a family out of the Cad File.....could use that info to help discern your plight.  Outside of that, are you using Worksets?  If so, place this particular "family" into it's own WS, and thenn you should be ale to control it's visibility.......You may also want  to look un VG>Imported Categories and see what is in there.
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
    thombrady
    Re: Link in the Way
    10-17-2012 10:33 AM in reply to: thombrady
    Thanks! Forgot about worksets...duh
    Active Contributor
    Re: Link in the Way
    10-17-2012 09:43 PM in reply to: thombrady
    Other option is to create a view template for sections either with the category off or that specific link turned off.  You are then able to selectmultiple views, right click and apply view template.  If it is only the visibility graphics you wish to apply then uncheck the other categories and apply.
