• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    BRYANBRAUER1832
    Key Plan Hatching
    201 Views, 1 Replies
    11-16-2012 06:13 PM
    Here is a question that was asked two years ago, without an answer.  I have the same question:
    I have a key plan I need to show on multiple sheets. The plan has 3 separate areas. I need to show only one area at a time. How can I accomplish this without placing a region on every sheet.
    Preferably I would like to place the key plan with the separate hatches (regions?) in the titleblock family then manipulate the hatche(s) through my sheets.
    Please use plain text.
    Active Contributor
    Re: Key Plan Hatching
    11-18-2012 03:35 PM in reply to: BRYANBRAUER1832
    http://www.augi.com/images/uploads/aec_edge/AAE2010Sum-lr.pdf
    AEC edge above contains an article on key plans by Paul Aubin.  I have seen another method where you clean up a view and do a drafting view snapshot which forms the background of your key plan then same thing with the yes/no parameters controlling visibility on fill regions.
