• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Accepted Solution
    Is there a reason to still be using the Space Naming Utility?
    200 Views, 1 Replies
    01-04-2013 01:57 PM
    Can someone give me a reason why we shouldn't change our Space Tags to read Room name and Number? One of our users asked me why we're still using the space naming utility and I couldn't come up with a very good reason. I can only think if maybe you already have some established schedules, but that would be simple to just change space name to room name. The other reason would be running a heating/cooling load analysis..... but let's be honest, who really uses that?
    Please use plain text.
    *Expert Elite*
    Re: Is there a reason to still be using the Space Naming Utility?
    01-06-2013 02:40 PM in reply to: abulla
    Do you reference Rooms that reside in a Linked Project? You can't really Schedule local elements based upon the Room Names/Numbers in a link - they are still scheduled by the Space's info. Also, there are minor things such as Panel Schedules, which can only reference the Space's Name/Number as the panel's Location parameter.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
