• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Installing Equipment that needs to be attached to a link
    157 Views, 3 Replies
    10-19-2012 10:39 AM
    I am working in Revit MEP 2012. I am trying to install an exterior wall hydrant on my domestic water system. The family I brought in needs to be attached to a wall. All of the walls in this project are in an architectural file that I have linked in. How can I get around this problem?
    Please use plain text.
    *Expert Elite*
    Re: Installing Equipment that needs to be attached to a link
    10-19-2012 11:05 AM in reply to: stait
    Revit doesn't 'see' "Walls" from a Linked file, so you'll have to convert the Wall-Hosted families to Face-Based families.
    Refer to this previous thread: Change Family Host Type
    Welcome to the Autodesk forums, stait!
    Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
    their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
    We hope you'll stick around a while and help strengthen the value of this community!
    Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    New Member
    10-19-2012 11:11 AM in reply to: CADastrophe
    How does one go about doing this? Its something that will occur in numerous places throughout my drawings, I am hoping that I can resolve all of these with one operation
    *Expert Elite*
    10-19-2012 11:33 AM in reply to: stait
    Unfortunately, there no easy way to do this. The best you can do is create a new Project and load in the Wall-Hosted Families (or use 'Transfer Project Standards' on the Manage tab) and then place one instance of each Type on a wall. You should be able to follow that process to convert them all pretty quickly using Copy/Monitor.
    Following the Copy/Monitor step, if you have a lot of Families/Types to extract, you can go to the application menu (the big 'R') » Saveas » Library » Families to export all of them at once**. That will place them all in the same folder so you can load them all into your Project at once, as well.
    **Note : this will export ALL families, including Annotations and Fittings, so I recommend using the Purge All command prior to the Saveas step.
    Edit: The Transfer Project Standards method won't work - it doesn't transfer Families.
