• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Importing AutoCad 3D
    173 Views, 1 Replies
    09-14-2012 04:43 AM
    I am trying to import architectual and structural from an AutoCad 3D file I created a family [mass] inserted the cad file but when I import the file into the project I recieve an error that reads "This family insance has too many edges. Remove unnecessary geometry or split the instance into multiple instances" Is there any way around this It will not let me import the family with this error. Thanks..
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Importing AutoCad 3D
    09-14-2012 05:51 AM in reply to: mike29787
    Instead of using the mass family, have you tried the generic model family template?
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
