• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Mentor
    Import IFC into Revit MEP - then Export to AutoCAD 3d solids.
    357 Views, 2 Replies
    08-21-2012 02:16 PM
    On one occasion we exported to DWG format from Revit with this IFC file open and got nested Block within Blocks... nested inside were Polyface Meches.
    Then we tweaked the export options to export as 3dsolid and not Polyface Meches and got Blocks within Blocks... nested inside were Bodies...
    The bodies file version was several times larger than the polyfaces meches... but the file with the polyface meshes was still quite large.
    Is there any option to force export as, (given this case), 3dSolids and not Meches or Bodies?... the goal of which is to have the lightest weight 3d file as possible.
    Your thoughts?
    Please use plain text.
    Product Support
    fernanda.firman
    Re: Import IFC into Revit MEP - then Export to AutoCAD 3d solids.
    09-05-2012 05:14 PM in reply to: mdhutchinson
    Have you tried exporting it using the ACIS Solids?
    Export to ACIS solids in DWG format:
    File>Export>CAD Formats>DWG
    In the Export dialog box>Modifiy the "Select Export Setup"
    In the "Solids" tab> ACIS solids
    Back to the Export dialog box>Export> Select the 3D views to export.
    Save.
    Hope that helps.
    Fernanda Lima Firman
    Revit Support Specialist
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    Valued Mentor
    09-07-2012 10:20 AM in reply to: fernanda.firman
    Yes we did try ACIS Solids... I think we got 3d Polyface Meshes even though we requested ACIS 3d Solids. I did see a blurb on a forum post about first saving as a Revit Project. Before this we didn't first save the project...
    Can you confirm the export is different whether you export with or without SaveAs a Revit Project first?  Remember the question is in relation to IFC Format.
