• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    *BIM is in
    How is everyone addressing pipe breaks where one pipe passes over another?
    422 Views, 11 Replies
    04-16-2009 03:08 AM
    This is an issue.
    Please use plain text.
    Employee
    Re: How is everyone addressing pipe breaks where one pipe passes over another?
    04-17-2009 12:20 PM in reply to: *BIM is in
    What exactly do you mean? The gaps that are created? You can turn those off if you want. Mechanical Settings -> Hidden Lines.
    Kyle B
    Industry Product Manager
    Kyle Bernhardt
    Product Line Manager
    Building Design Suite
    Autodesk, Inc.
    *BIM is in
    04-20-2009 04:15 AM in reply to: *BIM is in
    Thats just it, there are no gaps.If I have a pipe
    at 9' and another pipe at 10' 90 degrees to the other they show op as lines
    crossing ech other instead of a pipe break. (gap) to show that are not
    connected.
    What
    Kyle
    B
    Employee
    04-20-2009 10:02 AM in reply to: *BIM is in
    Sounds like you either have them turned off, or perhaps you have your view view Model Graphics Style set to Wireframe?
    Martin Schmid, P.E.
    Product Manager - Analysis and Countrification
    Architecture, Engineering, and Construction
    Autodesk, Inc.
    Valued Contributor
    04-20-2009 11:41 AM in reply to: *BIM is in
    I think the Gap Setting is a joke. If you mess with the setting it then will affect you fitting display as well. Your pipe rise and pipe down symbol are now screwd up.
    Revit shows everything, if there is not a fitting it is not connected. It does not matter which is on top. The contractor is going to install it the way they want anyway. Thanks 2 cents...
    Here is an example. Maybe there is an ideal setting that I don't know about but I have never been able to get this work properly.
    *KeN Etter
    04-21-2009 05:07 AM in reply to: *BIM is in
    Good point. The gap setting should not affect the pipe rise/down
    symbols. Autodesk needs to correct this.
    Novell....it does a server good!
    Distinguished Contributor
    04-22-2009 06:40 AM in reply to: *BIM is in
    I agree. There are also problems with duct items such as dampers in ducts and fittings.
    Autodesk's solution to us was to set it to zero. Therefore, no breaks at crossings. -useless
    Active Contributor
    04-22-2009 04:54 PM in reply to: *BIM is in
    Have you tried setting the hidden line to 3/128"? This is the closest number I can come up with to work half way descent with both ducts and pipes.
    Distinguished Mentor
    05-08-2009 11:46 AM in reply to: *BIM is in
    1.The reason is because you have a line weight greater than 1 applied to the pipe filter.
    2 Phases are overridden.
    3.I have seen some files with glitches. Just open Mechanical Settings and close it.
    Usually the culprit is #1.
    “Anything worth doing is worth doing poorly, until you can learn to do it well.”
    05-08-2009 01:24 PM in reply to: *BIM is in
    I was using "7/256" as my final choice. (really) That way you can say "yea, that's a break", or "no, that's a printer error."
