Autodesk Revit MEP
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How can i convert Revit to AutoCad with same Colours
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
235 Views, 1 Replies
10-28-2012 04:12 PM
Re: How can i convert Revit to AutoCad with same Colours
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-29-2012 07:34 AM in reply to:
engineer12ahmed
While you are in the DWG Export dialog selecting views/sheets, click on the "" button beside the pull-down under "Select Export Setup".
You'll have to create an Export Setup here to get a custom configuration, in which you can assign layer names and colors as desired. Beware, there are a number of limitations, such as element Phasing for example.
Corey D.
⁞|⁞ Please use the
.Accept as Solution and
Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
⁞|⁞ Please use the
